Compute processes interrupted. Processing can be resumed.
    • alaharimanish
      Whenever I try to Generate a surface mesh the following message pops up in the console:
      "Compute processes interrupted. Processing can be resumed."
      Can you please tell me a fix.
      How well will the selected cell sizes refine the surface/volume?  Which licence are you using?
    • xiaolin wang
      I also encountered the same problem, have you resolved it now?Could you plesase share the process of resolving it?
      Thanks
      If you share some information I we may be able to help.
    • xiaolin wang
      I did not prompt any errors during the calculation of two-phase flow, but the calculation was interrupted at the beginning. I hope to find the specific problem and continue my calculation process.
      thanks
      What were the last few lines before the error triggered? The message is after the failure, and isn't always that diagnostic.
      • xiaolin wang
        I have try to reduce the time-step, but this error still occurred. What other ways can I try?
        thanks
      Start with the mesh quality, and then move onto materials, boundary conditions and model suitability.
      • xiaolin wang
        OK, I will try, thank you !?
    • alaharimanish
      Yes, I was able to reslove it.. actually for me the problem occured during the surface mesh generation, i think you have done that.. I was doing the flow analysis on a propeller and I got this problem due to the sharp trailing edges. I resized the mesh in that area and the problem was fixed. Hope this helps.
Viewing 7 reply threads
  • The topic ‘Compute processes interrupted. Processing can be resumed.’ is closed to new replies.
