April 14, 2022 at 7:26 pm
stja
SubscriberEvery time I try to run my simulation in Fluent before it starts going through the iterations I get a Message from the Cortex Process saying that the Compute Processes Interrupted Processing can be resumed. It then tells me that the Calculation is complete without ever going through any iterations. I didn't have any errors before this step and I don't know if theres a way I can just resume or if there's a deeper problem?
-Thanks
April 15, 2022 at 6:49 pmkarthik.remella
AdministratorHello:
Something is not correct with the simulation. If this was working earlier, could you please try and set up the problem from scratch (starting with a mesh file clean)?
Karthik
April 15, 2022 at 8:59 pmstja
SubscriberI've tried setting up the problem multiple times and it's never gone through the iterations. I've redone the mesh multiple times and I've improved the mesh quality with no result. Is there some way I can see exactly what the problem is that the program is encountering?
April 19, 2022 at 12:24 pmkarthik.remella
AdministratorHello:
Could you please post some screenshots of your error as well as your run calculations settings?
Also, what I was asking for is to set up the model from scratch (instead of reading a new mesh into an existing case file)? Basically, launch a fresh instance of Fluent, read the mesh file, set up the Fluent model from scratch, and then run your model. I hope you have done this already.
Thank you.
Karthik
November 27, 2023 at 2:38 amNovember 28, 2023 at 2:21 pmRob
Forum ModeratorPlease post into a new thread for attention. Post any error or log files in with the message.Â
Viewing 5 reply threads- The topic ‘Compute processes interrupted Processing can be resumed’ is closed to new replies.
