December 19, 2024 at 6:24 am
December 20, 2024 at 11:25 am
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum.
Please let us know which Ansys Electronics tool you are using to help us serve you better. If possible please share some screenshots of your model.
Best regards,
Praneeth. -
December 26, 2024 at 2:18 am
March 6, 2025 at 7:18 pm
bryan.sandoval
Ansys EmployeeHello,
In the screenshot you provided, you may put desired current of 6 amps as the magnitude and then proceed to set-up frequency sweep in Near/Far field set-up (in the “Compute Near/Far field” pop-window” which is shown on slide 9 in the attached file. Here you will define frequency points of interest by defining your frequency sweep (or single points by adding another row to frequency range). Please see the screenshots below
This method show you the fixed 6 amp current at frequencies defined in the set-up, but if you are interested in having current dependent on frequency, then that’s when you will need to change from “Frequency Independent” to “Frequency Dependent” within your Set Current Source Properties window you are showing. In this case, you will need to define a .txt file that include data in .
Ansys Technical Support
Bryan Sandoval
5824
