November 26, 2019 at 10:18 pm
Veronica
SubscriberHi everyone,Â
I asked the following question above
/forum/forums/topic/compression-only-1/?reply=df034d31-7ba8-452b-9fcb-ab0f00fcc4d1#createpost
What will be the difference if I apply bearing load at the hole and displacement x=0 en the left edge. Because I have done this and now I have different results.
Best regards,
November 27, 2019 at 12:27 am
peteroznewman
SubscriberHi Veronica,
AÂ Compression only support creates a frictionless contact with a rigid surface. That is like putting a pin in the hole.
Bearing load creates a force on the nodes where the maximum force is at 0 degrees and zero force is at 90 degrees on either side and the distribution of force is sinusoidal.
So Compression only support and bearing load are slightly different.
Please show the two models using the same scale on the Legend to show the difference between the two models. If you want you can Attach your Archive .wbpz file to the post.
Best regards,
Peter -
November 27, 2019 at 4:09 am
November 27, 2019 at 8:49 am
Veronica
SubscriberThank you so much for your help, in your answer I think that with bearing support you are refering to compressión only support or am I wrong?
November 27, 2019 at 11:18 am
peteroznewman
Yes, I meant a compression only support. I edited the post above for clarity.
To make the same color legend on both plots, on the top plot, double click on the 0.059088 and type 0.04 while on the bottom plot, double click on the 0.047454 and type 0.04. Do the same on the negative end of the scale, replace -0.021088 and -0.024729 with -0.02. Finally click on the green square in the middle of the legend, a +/- will pop up. Click the minus to remove one square from the legend. If you have more than two plots to make equal, you can right mouse click on the legend and Name it, then just use that name on another plot.
Best regards,
Peter -
December 6, 2019 at 9:39 pm
Veronica
SubscriberThank you!
- The topic ‘compression only and bearing support’ is closed to new replies.
5964
1307
