September 23, 2023 at 6:35 am
Rachit Bundiwal
SubscriberHii , i am modelling a multiphase VOF problem and in it i need to run air as compressible and water as incompressible in a pressure based solver . can anyone help me out how to do that ?.
September 25, 2023 at 2:45 pm
SRP
Ansys EmployeeHi,
You need to air as a primary phase since it is compressible for better solution stability.
Can you please explain in more detail what exactly problem you are facing while modeling?
Thank you.
October 3, 2023 at 9:13 am
Rachit Bundiwal
SubscriberHi thanks for reply , i am trying to simulate a swirl flow using K-e RNG , using velocity inlet as BC , for both the inlets . but the problem arises during the initialization , when primary inlet is selected it is not showing it . And showing absurd values . Any resons for that ?
October 3, 2023 at 12:47 pm
Forum ModeratorYou may need to rethink how you initialise the problem. Pictures will help us understand what you're up to.
- The topic ‘Compressible and Incompressible flow modelling’ is closed to new replies.
5824
