July 13, 2024 at 6:23 pm
Zwernjayden
SubscriberWhen I use the non-premixed combustion model with the compressibility effects option on, it causes the continuity residual to increase and eventually cause a floating point error, where as with it off, the residuals drop. Any idea why that is?
July 15, 2024 at 10:45 am
Forum ModeratorIt means that something in the flow field is unstable with variable density and needs to be looked at. If you check the flow field what is different between the two cases?
- The topic ‘Compressibility effects causing floating point error, non-premixed combustion’ is closed to new replies.
