November 19, 2024 at 7:08 pm
Mudassarbhisty
SubscriberHi,
 I am working on composite pressure vessel analysis. Can anyone help me in plotting stress ( Max. principle stress or Normal Stress X- direction) vs Axial distance (along length of the cylinder) graph. I have attached a pic for your understanding. Suggest all possible methods to plot it.ÂNote: I have constructed the composite material part (composite winding) in ACP and transferred it to static structural module as solid composite data.Thanks -
November 20, 2024 at 10:49 am
Ashish Khemka
Forum ModeratorHi,
You can use 'Chart' to plot the stress variation along the axial distance:
Making Charts and Tables in ANSYS Mechanical - PADT
Ashish Khemka
November 20, 2024 at 11:57 am
Deepak
Ansys EmployeeHi,
You can also construct a path using the edge, and then the scope to the max. principal stress to that path.Refer link: Path
Thanks,
Deepak -
November 21, 2024 at 10:28 am
Mudassarbhisty
SubscriberHi,
Can anyone give me suggestion/ solution for the following issue, i am facing while running a static analysis of a composite pressure vessel.
I am getting significantly higher stresses at the bottom region of the bottom ply only. The neighboring elements have stress magnitude comparatively lower than this strip of elements. I have attached the images for your understanding.
Thanks
November 21, 2024 at 10:35 am
Viewing 4 reply threads
1890
1419
1304
