TAGGED: composite, failure, failure-criteria, pressure-vessel
March 7, 2024 at 8:06 am
harshanagasai668
SubscriberHello, I am able to use cut of section rule to get the varaible thickness. But the change in angle is still not changing even though i used lookup tables. And more over, the dome portion when analysed , it exceeded the failure index. I would be really helpful for me if someone can point out my mistake. Here i am attacing images for the reference. Even though the angle is specified in look up table, the change in angle is showing in the picture when i selected angle(show).
March 13, 2024 at 9:26 am
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps you: How can I setup variable winding (fiber) angles on a COPV (composite overwrap pressure vessel using ACP and tables capabiliity? The fiber angle changes in the dome region and I need to account for the changing angle. - Ansys Knowledge
Ashish Khemka
- The topic ‘Composite overwrapped pressure vessel.Dome with varible angle & thickness’ is closed to new replies.
3622
1303
1122
1068
1008
