LS Dyna
LS Dyna
Composite Modelling
    • Raghav
      Hi everyone,
      I am trying to do impact modelling on a thick composite plate. Each layer consists of solid elements. How to model composite plate properly.
      It will be very helpfull if anyone can share a model of the composite plate using solid elements. Please guide me through steps like when to use part_composite or part_solid. Any document that refers to complete modelling of composites will also be helpful.
      Regards
    • Raman Babu
      Hello Raghav,
      Please see the link below
      https://ftp.lstc.com/anonymous/outgoing/support/PRESENTATIONS/lsprepostcomposite.pdf
      https://ftp.lstc.com/anonymous/outgoing/support/FAQ/composite.models
      Please try it and let me know how it goes.
      Raman Babu
    • Raghav
      Hi Raman, thankyou for the links. They are really helpfull.
      Some doubts still remains and it will be helpfulll if you can guide me through it.
      1. What is the difference Between solid and T_Shell. id there any criteria for defining tshell similar to that of shell (L/T >50 ratio)
      2. I want to use solid elements, so using the solid elements can i define my part (lets say 10 mm thick) as 1 geometry containing and divide them into multiple layers of solid (lets say 10 layers of 1mm each) using Part_Composite or only shell elements can be used with this keyword as many examples either dipicts shell or T_Shell
      Thanks and regards
