November 2, 2023 at 4:34 pm
Noureldeen Radi
SubscriberHow Ansys calculates deformation in beams made out of isotropic materialsÂ
I used transformation section rule for solving for deflection analytically but the value is different around 22mm for Ansys apdl result and 52mm for analytical resultsÂ
November 3, 2023 at 2:11 pm
mrife
Ansys EmployeeHi Noureldeen
Before getting into materials, which beam theory did you assume in your hand calculations? Mechanical APDL uses Timoshenko beam theory for Beam188/189.
Mike
November 3, 2023 at 2:28 pm
Noureldeen Radi
SubscriberHello, my question was. Not clearÂ
I used she'll 181 fo so how ansys calculates the deflection and stresses on my beam.. I have a 4 point force and 3 isotropic materials in 1 composite lay-up... Finally all modeling is made in areas..
How ansys calculates it analytically?
And should I do any boundary conditions or initializing any equations?Â
- The topic ‘Composite materials in beams how Ansys calculates deformation’ is closed to new replies.
