July 8, 2024 at 3:33 am
I am trying to create a nodal reaction force versus displacement for a composite laminate subjected to an applied displacement over a given length of time. The composite coupon is constrained at one end with an applied displacement at the other end, as in a tension test. SHELL281 elements are used. The laminate is symmetric about the midplane and has 24 laminas. I am using progressive damage with the Hashin criteria. The laminate has a hole in the center.
What I am hoping to see is the drop in nodal reaction force at different points in the displacement due to the various layers becoming damaged at different times. I would expect to see something like the graph below.
Is this the code I should be using to generate such a graph? Is there a way to select all the nodes at the constained edge and plot them in one graph like the picture above?Â
!PLOT NODAL REACTION FORCE VERSUS DISPLACEMENT AT NODE 5616ÂLAYERP26,1Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !SELECT THE LAMINASHELL,MIDÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !SELECT THE MIDDLE LAYER IN THE SHELL ELEMENT FOR RESULTSRFORCE,3,5616,F,X,FX NODE 5616Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !DEFINE VARIABLE #3 = X-DIRECTION REACTION FORCE AT NODE 5616NSOL,2,5616,U,X,UXÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !DEFINE VARIABLE #2 = X-DIRECTION DISPLACEMENT AT NODE 5616/AXLAB,Y,REACTION FORCE [N]Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !LABEL Y-AXIS AS "NODAL REACTION FORCE"/AXLAB,X,DISPLACMENT [mm]Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !LABEL X-AXIS AS "DISPLACEMENT"PLVAR,3Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !PLOT VARIABLE #3 AS YXVAR,2Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â !PLOT VARIABLE #2 AS XÂ
The node I chose is a node at the periphery of that hole that becomes damaged during the applied displacement. Is this a correct choice of node given what I am trying to do?
Should I be using a stress versus strain graph instead?
Thank you!
July 31, 2024 at 10:02 am
Ashish Khemka
Forum ModeratorHello,
Please see if the following link helps: ANSYS 2024 R1 Student Mechanical APDL – Nodal Reaction Force – Composite PDA
Ashish Khemka
- The topic ‘Composite Damage – Nodal Reaction Force vs. Displacement Graph’ is closed to new replies.
6680
1313
