November 10, 2021 at 1:07 am
jhale
SubscriberHi,
I am trying to get my model to detach using a cohesive zone model. I followed the ANSYS tutorial, but my model did not detach. I applied a displacement to the top part and the bottom part is fixed. Below are my results and setup.
November 19, 2021 at 6:48 pmFebruary 2, 2022 at 9:08 pmDevashish Sarkar
Ansys EmployeeIt seems the model used shared topology. Match control method(Interface Delamination Application (ansys.com) needs multibody parts without shared edge.
An alternative to this method is also Contact debonding which is more robust and less sensitive to mesh. Hope this helps!
Viewing 2 reply threads- The topic ‘Compliant material not detaching from stiff substrate using cohesive zone model.’ is closed to new replies.
2778
965
841
599
591
