TAGGED: impedance, lumped-port, patch-antenna, unit-cell
September 27, 2023 at 5:13 am
Russell Raldiris Torres
SubscriberWhen specifying a complex impedance for lumped ports in an HFSS design for FEM simulations in unit cell analysis, I get very strange results that don't look correct, specifically in the 400-420 GHz range. For example, in the port impedance I specified 76.9-1i*75.46 (per the HFSS menu setup recommendation) and then simulate. Looking at the S11 return loss we see the following:
Background, this a simple patch antenna with 3 ports.
Is there anything we need to setup prior to using complex impedances? What could be causing this type of response?
Any help is appreciated, thank you!
September 28, 2023 at 12:07 pm
Praneeth
Ansys EmployeeHi Russell,
Thank you for reaching out to the Ansys learning forum.
Did you normalize the port impedance while defining the lumped port? Please share the snap of the lumped port definition in your model to help us serve you better.
Best regards,
Praneeth. -
September 30, 2023 at 12:19 am
September 30, 2023 at 7:01 pm
SubscriberHi Praneeth,
I discovered a older post with the solution. The settings had to be modified per the post: "The solution to this issue was to change the S parameter definition from the default of Generalized in Design Settings to Power which corrects the issue and plots negative return loss values."
Here is the link: /forum/forums/topic/complex-lumped-port-impedance/
My issue is resolved.
- The topic ‘Complex Impedance for HFSS Design’ is closed to new replies.
5799
