July 17, 2021 at 4:05 pm
Makara
SubscriberI have one question to discuss with you that I use fluent to run 2D channel flow and I get result of Volume flow rate at x=0m (Volumetric Flow Rate= -0.0001978993 m3/s) but My professor want me to calculate the Volume flow rate using Simpson 1/3 rule while using the Velocity at x=0 from solution data in fluent but after my calculation I got Volume flow rate at x=0m (Volumetric Flow Rate=0.000180 m3/s) and percentage difference is 9.04%. is it the same velocity which fluent use to calculate Volume Flow rate compare to the velocity that export from solution data of ASCII File that I used to calculate volume flow rate using Simpson 1/3 rule?
July 19, 2021 at 9:36 amDrAmine
Ansys EmployeeI do not trust 100% reporting on user defined planes or cross sections. Fluent is not solving for Volumetric Flow Rate.
Can you please add more details how you are using using the Simpson Law to get flow rate?
July 19, 2021 at 9:40 amDrAmine
Ansys EmployeeFlow rate will be Velocity times the area and the area along y will be the facet area for each U. Also try exporting using cell center values but again: user defined post-processing planes won't be accurate compared to boundary values (there is no facet area associated with them.)
July 21, 2021 at 6:13 amJuly 21, 2021 at 6:30 amDrAmine
Ansys EmployeeOkay. Thank :)
July 25, 2021 at 2:10 pmMakara
SubscriberHello Sir
I have one more question about my 2D problem that I try to export X-velocity solution data using ASCII file type that I already create the node point. when I export using Cell center and node the result is much difference so how ANSYS calculate the Cell Center X-velocity in 2D? How can I convert Node to Cell Center?
Thanks
Best Regards
K. Makara
July 26, 2021 at 1:11 pmRob
Forum ModeratorThe values are usually fairly similar if the mesh is well refined. How different are the positions and x-velocity?
July 27, 2021 at 3:42 pmMakara
SubscriberI used 3 node to export the data from fluent. The velocity when I export using Node it come up with Node 1= 0.00 m/s, Node 2=0.005m/s, Node 3=0.01 m/s. But we export using Cell center. it come up with Node 2=0.00916 m/s. so I still wonder where and how fluent calculate the Cell Center?
Thank you.
Best Regards
K. Makara
July 27, 2021 at 3:53 pmRob
Forum ModeratorWhat value of x position does the cell centred value have?
July 27, 2021 at 4:39 pmJuly 28, 2021 at 10:30 amRob
Forum ModeratorPlot both lines on the same graph in Excel and post the results.
July 28, 2021 at 1:14 pmJuly 28, 2021 at 1:44 pmRob
Forum ModeratorShowing a difference of 1%. Now replot with the x-position v y-position.
July 28, 2021 at 2:05 pmJuly 28, 2021 at 3:06 pmRob
Forum ModeratorWhich may be the interpolation onto the lines. How well refined is the mesh?
July 28, 2021 at 3:28 pmJuly 28, 2021 at 4:12 pmRob
Forum ModeratorPretty much. Double the resolution (use adaption) and try again.
July 29, 2021 at 6:51 amDrAmine
Ansys EmployeePretty much related as Rob mentioned to interpolation of the values to the line you created. I will be good to plot the lines in yellow colors on the last mesh picture you shared.
July 30, 2021 at 5:16 pmMakara
SubscriberThank you very much for you solution. Now I get the result between node and cell-center is about 1% different after use adaption. you are the best to me.
July 30, 2021 at 5:22 pmMakara
SubscriberOne more question. I have export all the node using ASCII file and I can see the node number in that file and I want to compare that node number with Fluent but I don't know the Node and Element number in Fluent. How could I see the Node number and Element number in fluent?
Thanks
best regards
K. Makara
July 30, 2021 at 5:25 pmAugust 2, 2021 at 2:49 pmRob
Forum ModeratorI don't think you can. The node IDs change if you re-order the mesh so they're not used very much: we always focus on position.
August 3, 2021 at 1:22 pmMakara
SubscriberThank your for helping me.
Best Regards
K. Makara
August 3, 2021 at 1:51 pmDrAmine
Ansys EmployeeI do not understand: do you want to see that node numbering in Fluent as contour? If yes: not possible out of the box. You can however show the cell ID in Fluent.
August 3, 2021 at 4:56 pmAugust 4, 2021 at 11:05 amRob
Forum ModeratorWhy not compare the position?
August 4, 2021 at 11:13 amDrAmine
Ansys EmployeeYou can post the node number: just compare as Rob mentioned with position. I sincerely think this step you are doing is not necessary: you are just losing your time trying to check if the values are correct.
Viewing 26 reply threads- The topic ‘Compare between Volume Flow Rate and calculation with Simpson 1/3 rule.’ is closed to new replies.
6400
