Photonics
Photonics
Common Mode Rejection Ratio
    • minusunny
      I am trying to calculate CMRR using the equation below:
      Should  i take the value from transmission or the absolute square value of S? Are both of them same?
    • Afroditi Petropoulou
      Dear Minu,
      If you are using ports, you can use either the square value of S or the T_out result from the mode expansion result of the port for each mode.
      Best Regards,
      Afroditi
  • The topic ‘Common Mode Rejection Ratio’ is closed to new replies.
