Commands to run apdl macros via python scripting in Ansys mechanical
    • Nicola Tegas
      Hi everyone, I've been looking for a solution to this problem for a while but at the moment I can't find any solutions.
      I'm trying to automate the FEM analysis of a model that currently uses different apdl macros that work great. Currently these five different macros create a heatmap of the model via external files.
       Block run with various APDL Macro
      My goal is to delete the various macros that I insert inside the run block and keep them in an external folder, these will have to be called from a python code that will be in the run block.
      Block run with Python code
      In this way the end user will only have to click on "Solve" to obtain the results of the model, while now the various macros must always be updated again.
      Does anyone know any commands I can insert into the Python code to run the APDL macros that I would like to keep in an external folder?
      Thank you in advance
    • Aniket
      Hi Nicola, Please check the following extension on app store:
      https://catalog.ansys.com/product/5b3bc6857a2f9a5c90d32e06/command-obj-to-act
      this contains source code, so with some efforts you should be able to convert all you apdl extensions to an ACT app.
      -Aniket
      Forum Rules & Guidelines
  • The topic ‘Commands to run apdl macros via python scripting in Ansys mechanical’ is closed to new replies.
