Combining result file from expansion pass?
    • faristhottoli
      Hello everyone ,
      I am facing trouble in combining result from expansion pass of multiple substructure to get whole result in one file. I tried using RESWRITE command but the file obtained only contain result of one substructure. Can anyone suggest the procedure for doing this
      Thanks
    • Vigneswaran Sridharan
      Hi I was wondering if the 'RAPPND' command helps you?
      RAPPND (ansys.com)
      Also, this might interest you Solution Combination (ansys.com)
      Vigneswaran
      How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
    • faristhottoli
      RAPPND Seems to be used for appending solution for same model for multiple load , what I require is to combine multiple substructure result to give me the full model result. My model have a repeating unit pattern which has been modeled as super element, I solved it using USE and Expansion pass , now how to combine the result from expansion pass to give me full model in APDL is my query.
      Thank you
  • The topic ‘Combining result file from expansion pass?’ is closed to new replies.
