August 1, 2024 at 6:34 pm
Shahriar Kahnamooi
SubscriberDear Forum Members,
I need help combining ANSYS Mechanical APDL result files (.rst) from two separate simulations into one sequentially.
**Background:**
I ran two static structural analyses on the same model with different load conditions:
1. **System A:** Force in Z direction (`file.rst` of System A).
2. **System B:** Force in X direction (`file.rst` of System B).Both simulations share identical structures (geometry, material, mesh, contact conditions, etc.).
**Objective:**
Combine the `file.rst` of System A and System B into a single `file.rst`, with Load Step results sequentially arranged as if run in a single simulation with two load steps from the beginning.
**Request:**
Seeking advice, scripts, or methodologies to combine .rst files while preserving Load Step results. Interested in ANSYS Mechanical APDL commands, scripting techniques, or third-party tools.
**Note:**
I am not looking for suggestions on combining distributed result files such as `file0.rst`, `file1.rst`, `file2.rst`, `file3.rst`. This has nothing to do with distributed result files.
Thank you for your assistance.
Best regards.
August 2, 2024 at 1:19 pm
Gary Stofan
Ansys EmployeeÂ
Windows Command line / DOS copy command with appropriate switches can be used to append one file to another.Â
Q: What is the expected benefit of combining the result files?Â
August 6, 2024 at 10:34 am
Shahriar Kahnamooi
Subscriber[placeholder]
January 30, 2025 at 10:52 am
gopinath.m
SubscriberHi,Â
can you please explain in detail "Windows Command line / DOS copy command with appropriate switches can be used to append one file to another"?
January 30, 2025 at 2:05 pm
Gary Stofan
Ansys EmployeeInternet search for "dos copy file append after" produces several examples.
Combining of result files in this manner is not supported, but may work for your purpose.
6044
