November 10, 2023 at 11:28 am
SUJAN DHAKAL
SubscriberHow can I calculate power, torque, coeff of power and rpm of the vawt geometric parameterization of radius of savonius and height of darrieus so that I can get the suitable dimensions that gives max output power at constant air speed?
November 14, 2023 at 2:36 pm
Federico
Ansys EmployeeIs this an Ansys question?
November 14, 2023 at 5:54 pm
SUJAN DHAKAL
SubscriberYeah I am using ansys fluent for the simulation but I got stuck in the setup/solution section on how to get the outputsÂ
November 14, 2023 at 5:58 pm
Federico
Ansys EmployeeYou can set up report definitions for Moment and get torque and combine it with angular velocity to get power via a Named expression
November 14, 2023 at 6:00 pm
SUJAN DHAKAL
SubscriberWhen I tried to run simulation at constant air speed of 6 m/s the simulation gets stuck after certain iterations. What might be the problem?
November 14, 2023 at 6:30 pm
Federico
Ansys EmployeeYou will need to provide more details to help us troubleshooting. What gets stuck? the convergence? the iteration? what does it say in the console?
November 17, 2023 at 3:07 pm
SUJAN DHAKAL
Subscriber -
November 17, 2023 at 3:09 pm
November 17, 2023 at 3:11 pm
November 17, 2023 at 3:14 pm
November 17, 2023 at 3:23 pm
November 17, 2023 at 3:27 pm
November 17, 2023 at 3:30 pm
January 27, 2024 at 3:10 pm
hamdy atef
- The topic ‘Combined Savonius-Darrieus Wind turbine’ is closed to new replies.
5744
.png)
