TAGGED: load-combination, seismic, solution-combination, static
July 5, 2024 at 5:58 am
vvaibhav1002
SubscriberHi all.
I am doing a static structual and seismic analysis of a structure which I made using line bodies. The problem I am facing is that I have seperate results of stresses and deformations of static structural and seimic(response spectrum), I am not able to combine those these results, means, I want to stresses and defromations of combine static and seismic loading.
Please let me know how can I combine the result.
July 8, 2024 at 10:25 am
Lydia Lymperopoulou
Ansys EmployeeHi,
You can try the Solution Combination object 18.17.12. Solution Combination (ansys.com). I don't know which release you are using so I 'm not sure if the feature has its current capabilities. You shall check the corresponding help documentation.
- The topic ‘Combination of seimic and structural analysis’ is closed to new replies.
