November 14, 2023 at 1:36 pmyifan liu SubscriberHello,
 I encountered a problem when I used the UDF “DEFINE_CG_MOTION” and sliding mesh, the warning message below popped up during simulation: Warning: incompatible interaction between moving mesh and dynamic mesh model.Model and settings description: 1)the black one is blade,the red one is Trailing edge flap 2)The sliding grid method is used to control the rotating motion of the blade and flap around the y axis  3)I use “DEFINE_CG_MOTION” to control the swing of the trailing edge flap around the contact axis with the blade
November 14, 2023 at 2:18 pmFederico Ansys EmployeeI would recommend you set the blade motion using Dynamic Mesh
November 15, 2023 at 3:15 amyifan liu SubscriberI tried, but the trailing edge flaps need to swing relative to the blades while rotating with the blades, so the movement of the trailing edge flaps is too complex to be fully realized with a udf -
November 15, 2023 at 1:19 pmFederico Ansys EmployeeYou can set the motion as Relative Motion to a zone, even in Dynamic Meshing
November 16, 2023 at 7:50 amyifan liu SubscriberThank you for your suggestion,I will try this way
- The topic ‘Combination of moving mesh and dynamic mesh’ is closed to new replies.
- affinity not set
                        4167
                        1487
                        1358
                        1189
 You are navigating away from the AIS Discovery experience
