LS Dyna
LS Dyna
Collision SImulation
    • Ariq Indra Pratama
      I tried to simulate a collision in LS-DYNA. but what i found is my model penetrate to other body which supposed to be solid. the other problem is i can't find the impact on the striking area. any idea what should i do to fix this problem?
    • Armin
      Hi Ariq,
      Could you describe the way you considered the interactions between the two parts in your model? Did you specify any contacts or body interactions?
    • Alex Rycman
      Hello Ariq,
      Please find attached an article about the contacts in LS-DYNA for a full vehicle impact scenario. https://www.dynasupport.com/tutorial/contact-modeling-in-ls-dyna/modeling-guidelines-for-full-vehicle-contact
      If you are missing a contact card, please add it to the input deck. I would suggest starting with *CONTACT_AUTOMATIC_SINGLE_SURFACE.
      Please let us know how it goes.
      Thank you,
      Alex
  • The topic ‘Collision SImulation’ is closed to new replies.
