October 1, 2018 at 9:28 pm
hugo CFD
SubscriberHello
I'm studying a quasi counter flow flat plate heat exchanger. In the simulation study I used hex elements in the multizone method.
When I apply inflation, a message "collision detected- have been removed" appears.
How can I resolve the error?
Thanks
October 2, 2018 at 1:07 am
Marco Coderoni
Ansys EmployeeYou may want to try changing the options of the collision avoidance. For more info you can take a look at this discussion:Â
/forum/forums/topic/what-are-the-collision-avoidance-methods/
October 2, 2018 at 1:31 am
Keyur Kanade
Ansys EmployeeIn short, you can use layer compression in advanced settings. If that also does not help then please reduce total prism height by reducing no. of layers or first height or growth rate.Â
In certain cases, you may also want to think of modifying geometry to increase gap between two walls.Â
Hope this helps.Â
Keyur
- The topic ‘Collision – inflation layer’ is closed to new replies.
3767
1333
1168
1090
1014
