June 16, 2019 at 11:06 pm
May 19, 2020 at 3:07 am
zoeartesyn
SubscriberIÂ think both two functions you mentioned had the same current conducting path. But you can by section the rotor bar in the position you want, and create a surface, then assign coil terminal.
May 19, 2020 at 3:09 am
zoeartesyn
SubscriberIt's worth mentioned that coil terminal must be added at the edge of a region. I don't think your way had a closed circuit.
May 20, 2020 at 12:20 pm
- The topic ‘Coil Terminal’ is closed to new replies.
1836
1387
1248
