July 11, 2023 at 10:23 pm
Amiri Savage
SubscriberHi, I want to run a simple 2D simulation with a solid material and an adhesive polymer in Ansys. I want to induce an increasing stress on the solid material till failure. I'm having some difficulty defining the cohesive zone model. Specifically determining the correct contacts.
Would appreciate any insight in correct contact creation procedure.
July 12, 2023 at 6:28 am
ErKo
Ansys EmployeeÂ
Hi
This tutorial shows how to set up a CZM model:
https://www.youtube.com/watch?v=qBdI9D4fNjQAll the best
Erik
July 12, 2023 at 5:48 pm
Amiri Savage
SubscriberHi Erik,
Thank you so much for responding. Another question I had was how do you determine the material properties of the CZM material. I wasnt sure where i could find maximum normal traction, or normal separation across the interface. Is this something that we should assume? Also I assume this would change if I wasnt creating a model with a premade crack, correct?
Thank you,
Amiri Savage
- The topic ‘Cohesive (Adhesive) behavior ANSYS mechanical’ is closed to new replies.
5899
1306
