October 6, 2024 at 12:54 am
dd1367
SubscriberI have been trying to simulate flow over a wing of 1m chord length and 5m span(the airfoil of the wing is goe 464) and inlet velocity of 36.11m/s.I am getting a cl of approx 2.6 which is very different from xflr5 result of 0.6(approx) for the same condition I am using k-omega sst for simulation and I have also provided the inflation layer with help of the y+ value.
Why is there so much difference in the cl value and what can i do to correct the value of my cl in ansys
October 7, 2024 at 9:28 am
Forum ModeratorHave you corrected for area? Have a look at the various NACA tutorials/examples in Help. The coefficients are defined relative to a reference, and that reference is rarely the same as the Fluent default.Â
October 7, 2024 at 10:47 am
dd1367
SubscriberHello,thank you very much for the comment,can you pls share any link regarding this and why does the refrence value effect the cl this much??(as in the mathematical/code reason)
October 7, 2024 at 10:57 am
Forum ModeratorMaybe start by clicking on Help and searching for lift coefficient and then looking for the tutorials? Learning on here may also have some relevent material.Â
October 7, 2024 at 10:59 am
dd1367
Subscriberok thank you very much for your help
5754
