October 28, 2023 at 2:17 pm
İlker
SubscriberCan I ask you something?How do we calculate the values on the side of the codes in the example I gave?*SET,_FNCNAME,'HEATFLX'Â *DIM,_FNC_C1,,1Â *DIM,_FNC_C2,,1Â *DIM,_FNC_C3,,1Â *DIM,_FNC_C4,,1Â *DIM,_FNC_C5,,1Â *DIM,_FNC_C6,,1Â *SET,_FNC_C1(1),8625279.2 ! A = Beam power density (pW/um2)*SET,_FNC_C2(1),-2 ! B = -2 for Gaussian, -3 for Goldak*SET,_FNC_C3(1),0.0 ! C = X offset*SET,_FNC_C4(1),-10.0 ! D = Y velocity*SET,_FNC_C5(1),15 ! E = Y offset*SET,_FNC_C6(1),1.5 ! F = Beam radius*SET,_FNCCSYS,12Â *DIM,%_FNCNAME%,TABLE,8,16,1,,,,%_FNCCSYS%Â ! ! Begin of equation: A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F^2)*SET,%_FNCNAME%(0,0,1), 0.0, -999Â*SET,%_FNCNAME%(2,0,1), 0.0Â*SET,%_FNCNAME%(3,0,1), %_FNC_C1(1)%*SET,%_FNCNAME%(4,0,1), %_FNC_C2(1)%*SET,%_FNCNAME%(5,0,1), %_FNC_C3(1)%*SET,%_FNCNAME%(6,0,1), %_FNC_C4(1)%*SET,%_FNCNAME%(7,0,1), %_FNC_C5(1)%*SET,%_FNCNAME%(8,0,1), %_FNC_C6(1)%*SET,%_FNCNAME%(0,1,1), 1.0, -1, 0, 1, 2, 2, 19 <-- how to find this data??*SET,%_FNCNAME%(0,2,1), 0.0, -2, 0, 2, 0, 0, -1Â*SET,%_FNCNAME%(0,3,1), 0, -3, 0, 1, -1, 17, -2Â*SET,%_FNCNAME%(0,4,1), 0.0, -1, 0, 1, 20, 3, 1Â*SET,%_FNCNAME%(0,5,1), 0.0, -2, 0, 1, 3, 2, -1Â*SET,%_FNCNAME%(0,6,1), 0.0, -1, 0, 1, -2, 2, 21*SET,%_FNCNAME%(0,7,1), 0.0, -2, 0, 2, 0, 0, -1Â*SET,%_FNCNAME%(0,8,1), 0.0, -4, 0, 1, -1, 17, -2Â*SET,%_FNCNAME%(0,9,1), 0.0, -1, 0, 1, -3, 1, -4*SET,%_FNCNAME%(0,10,1), 0.0, -2, 0, 1, 18, 3, -1Â*SET,%_FNCNAME%(0,11,1), 0.0, -1, 0, 2, 0, 0, 22*SET,%_FNCNAME%(0,12,1), 0.0, -3, 0, 1, 22, 17, -1Â*SET,%_FNCNAME%(0,13,1), 0.0, -1, 0, 1, -2, 4, -3Â*SET,%_FNCNAME%(0,14,1), 0.0, -1, 7, 1, -1, 0, 0*SET,%_FNCNAME%(0,15,1), 0.0, -2, 0, 1, 17, 3, -1Â*SET,%_FNCNAME%(0,16,1), 0.0, 99, 0, 1, -2, 0, 0! End of equation: A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F^2) -
October 30, 2023 at 2:26 pm
mrife
Ansys EmployeeHi Hasan
The format of tables from the Mechanical APDL function tool is not documented. Mike
October 30, 2023 at 6:19 pm
İlker
SubscriberThe values in this table are handwritten values. That's why I'm asking.
October 30, 2023 at 6:21 pm
İlker
Subscriberhttps://www.youtube.com/watch?v=HsohSHa0L6s&t=94s this video
How were these values written?
My goal is to obtain a temperature distribution as in the relevant video, and then to obtain material depth. I want to remove paint from the surface.
October 30, 2023 at 7:39 pm
mrife
No, the values in the table were not hand written. The video creator used Mechanical APDL interactively to create the equation and evaluate it over a time range. Then exported it out - the exported APDL text version was then copy/pasted to the WB Mechanical Commands Object. They just did not show those steps.
See for example this Forum discussion:
/forum/forums/topic/mathematical-function-in-ansys-apdl/
mike
- The topic ‘Code Write’ is closed to new replies.
