December 4, 2023 at 3:57 pm
smostafayi
SubscriberHello everyone
I am trying to model CO2 dissolving from the gas phase to the liquid phase (water). In the manual for species mass transfer in the phase interaction, it is noted that : the gas phase must be selected as "to-phase". How should I consider the transfer of CO2 from the gas phase to the liquid phase (using Henry Law and two ressitance model"? Should I select the gas phase as "to-phase" ??!Â
December 5, 2023 at 2:17 pm
Forum ModeratorYes. Fluent doesn't know what a gas or liquid is, so for phase change the "from" and "to" phases are important. The enthalpy is then used to work out the energy balance. Note, the disolution energy is different from the latent heat so you may need to check the material properties.Â
December 6, 2023 at 3:21 am
smostafayi
SubscriberThank you for your response.
So, you mean whenever we want to have a mass transfer from the gas mixture to the liquid mixture, or vice versa, we should consider the gas phase as the "to-phase"? Â
December 6, 2023 at 9:10 am
Forum ModeratorIf that's the order in the manual, yes (I always have to check!). If the phase change is to the liquid Fluent will return a negative transfer coefficient, ie move the mass to the "from" phase.Â
December 10, 2023 at 8:54 pm
smostafayi
SubscriberThanks for answering.Â
I am trying this model, but I have serious problems with the energy. The model gives very high temperature values for both phase, and I can not understand what can be the reason for this? Do you have any suggestion? What should I check?
December 12, 2023 at 11:11 am
Forum ModeratorIf temperatures are very high check the boundary conditions and whether you've accidentally got an extra few 00s in the formation enthalpy of one phase or the other.Â
- The topic ‘CO2 dissolving in water using Eulerian Model Phase Interactions’ is closed to new replies.
5664
1890
1419
1304
