April 11, 2024 at 1:01 pm
Ali Muheidat
SubscriberI am using Maxwell 2D to design Prius 2004 PMSM, and I want to develop control system using Simplorer but I faced a problem and I need help.
Firstly, I developed the model using Maxwell 2D and I applied specific three phase current, and I recorded the Torque.
Then, I enable Transient - Transient link to couple the model with Simplorer, and I changed the excitation to external excitation.
After that, I injected same three phase current buy using three phase current source to the input winding, and I connected a speed source of (3000 rpm) to the motion setup out .
Also, I shorted the output winding of the motor and I connected the motion_setup_in to the ground.
Finally, I analysed the model but the output Torque is not similar to the Torque produced from Maxwell 2D.
How can I fix this problem?
Thanks.
April 19, 2024 at 2:34 am
HDLI
Ansys EmployeeÂ
Hello Ali,
   Please compare current, speed, postions, etc. in Maxwell models of both simulations, to make sure if everything is same.Â
   I belive something is different and the co-simulation results should be same with the Maxwell model with current excitation.
HDLI
November 21, 2024 at 7:50 am
hassan.currimbhoy
SubscriberHello,Â
I am having the exact same issue!
I have posted a more detailed explanation to my problem under the following link:
https://innovationspace.ansys.com/forum/forums/topic/simplorermaxwell-cosimulation-results-and-maxwell-results-mismatch/Some guidance here would be highly appreciated.Â
Hassan
- The topic ‘Co-simulation using Maxwell and Simplorer’ is closed to new replies.
6500
