April 30, 2021 at 7:15 am
Mquadrat
SubscriberHello,
I am currently building a coupled simulation from Maxwell and Twin Builder. I would like to implement an exchange of parameters among each other. Via a parameter set I have already managed that an output parameter of Maxwell, such as the resistance of a coil, became an input parameter of Twin Builder. But how can I access this parameter in the Twin Builder now?
Many thanks in advance and best regards.
May 4, 2021 at 2:54 pmrmagargl
Ansys EmployeeHello To access the Maxwell variable from Twin Builder, just double click the Maxwell co-simulation block once placed on the Twin Builder schematic. On the Quantities tab, any Maxwell variables should be listed, probably towards the bottom, as Input Quantities. You can change the value there, or add a Simplorer variable to change parametrically in Twin Builder. Let us know if you still have trouble.
Best Ryan
May 4, 2021 at 4:24 pmMquadrat
SubscriberHello Ryan thank you very much for the quick reply. However, my problem is to get the inductance of a coil from the Eddy Current simulation into the Simplorer. I then want to use this value to determine the corresponding capacitance for the resonant frequency.
May 12, 2021 at 7:59 amHan_JC
SubscriberMy work is very similar with yours
Viewing 3 reply threads- The topic ‘Co-simulation Maxwell/Twin Builder parameter exchange’ is closed to new replies.
3276
1036
1004
859
798
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
