Electronics
Electronics
Co-simulation between Ansys IcePak and Simplorer
    • hkanakri
      I have two questions:
      1- Does Icepak in AEDT support co-simulation with Simplorer? (i.e. similar to an actual transient to transient link).
      2- Can I link the IcePak ROM model to the actual IcePak 3D model ? I need to see the effect of real time simulation in Simplorer on the 3D model in IcePak.
      Best Regards,
      Haitham
    • Nikhil Tamhankar
      Hi Haitham Unfortunately the data can only be transferred once in a one-way fashion from Icepak to Simplorer ( now known as Twinbuilder), since it uses the data files created by Icepak as input for the ROM. 2- way transient link is not possible and the workflow itself is to avoid running multiple transient runs and reduce overall simulation time by using a ROM.
      So the answer is NO to both of your questions.
      Regards Nikhil
  • The topic ‘Co-simulation between Ansys IcePak and Simplorer’ is closed to new replies.
