May 15, 2023 at 8:55 am
May 15, 2023 at 10:08 am
Forum ModeratorI suppose the first question is: what do you expect to see? Second one is why do you have overlapping cell zones?Â
May 16, 2023 at 3:51 am
hone zifu
Subscriber -
May 16, 2023 at 10:35 am
Forum ModeratorHow did you set up the pad motion?Â
May 17, 2023 at 2:16 am
May 17, 2023 at 3:34 am
May 17, 2023 at 10:32 am
Forum ModeratorHave a look at sliding mesh or reference frames depending on whether the pad moves relative to the inlet. Does the slurry fill the whole fluid domain?
May 17, 2023 at 4:41 pm
hone zifu
SubscriberI didn't refer to the sliding grid, because I didn't take into account that the rotation is a plane, not geometry, and the liquid part will not flow to the entire area.
May 18, 2023 at 12:59 pm
Forum ModeratorIf you have no rotation why do the vectors in the original image go around the domain, and why does the second figure have arrows implying rotation?Â
May 18, 2023 at 5:06 pm
hone zifu
SubscriberI only have to rotate the face, but I have not set a moving mesh
May 19, 2023 at 9:23 am
Forum ModeratorOK.Â
If you ran transient did you save data or take an image at each (or regular interval) timestep?
May 19, 2023 at 10:32 am
hone zifu
SubscriberBecause now I'm not sure if my flow field setting is correct, so I haven't done that yet
May 23, 2023 at 3:21 am
hone zifu
SubscriberWhere do I need to modify the boundary conditions?
May 23, 2023 at 2:29 pm
Forum ModeratorAs I can't see exactly what the motion is supposed to be it's difficult to comment.Â
- The topic ‘cmp flow field analysis’ is closed to new replies.
