July 26, 2023 at 10:23 am
Oliver Sange
SubscriberHey,
I am trying to build a custom model library using the CML compiler. I deployed a Lumfoundry template and ran the CML compiler. I got the error message:
### Lumerical CML Compiler - Version: 3.7.3457
### Compiled with INTERCONNECT - Version: 9.12.3457
### Building compact models...
### ERROR: CML Compiler exited prematurely with the following error:
Exception: Failing to start INTERCONNECT! Please verify paths and licenses.
My Interconnect works perfectly fine, even if I launch it directly from the CML compiler GUI. Does anyone know a solution?
Regards
Oliver
July 26, 2023 at 6:41 pm
Dev
Ansys EmployeeHi, Can you try Step 3 : System requirements and installation – Ansys Optics
Then restart the CML compiler. Make sure to close interconnect windows also.
Please let me know this solved the issue.
Thanks
July 31, 2023 at 3:28 pm
Oliver Sange
SubscriberHello,
thanks for your help.
I tried adding the prompt into the Path variable. Unfortunately I still get the same error message.
Is there another possible solution?
Regards
Oliver
July 31, 2023 at 8:39 pm
August 1, 2023 at 8:07 am
Oliver Sange
SubscriberYes, I am.
August 2, 2023 at 12:05 pm
Oliver Sange
SubscriberIs there another possible solution? Reinstalling everything also didn't help.
August 2, 2023 at 1:02 pm
Dev
Ansys EmployeeÂ
New version of software is released. Have you tried installing that? Make sure to restart the system also. We are looking into the issue.Â
August 2, 2023 at 1:04 pm
Oliver Sange
SubscriberYes, I did download the latest version.
August 2, 2023 at 7:02 pm
Dev
Ansys EmployeeHello,
Try this:
delete the license.ini and interconnet.ini file and try again.
August 3, 2023 at 9:51 am
Oliver Sange
SubscriberThanks for your help.
August 3, 2023 at 3:55 pm
Dev
Ansys EmployeeIs everything working now?
August 4, 2023 at 8:23 am
Oliver Sange
SubscriberYes.
Regards
Oliver
- The topic ‘CML Compiler License error’ is closed to new replies.
5984
1307
