January 6, 2025 at 6:45 pm
Fabián
SubscriberDear all,
I'm using a harmonic response analysis with a clustering parameter of 20 given the very high quality factor of the resonaces. While this works around the peaks, values away from the peaks are not caculated:
I tried using the clustering together with user defined frequencies, but the clustering is overridden and the sharpness of the peaks is lost or not well characterized by the automatically selected frequencies.
Any ideas on how to calculate values away from the peaks while using the clustering option?
Thank you very much in advance.
Fabián
January 7, 2025 at 8:00 am
Harshvardhan
Ansys EmployeeHi,
Selecting the option for cluster results automatically cluster solution points near the structure’s natural frequencies ensuring capture of behavior near the peak responses. If you need uniform spacing of data points, turn this option off.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
