November 7, 2019 at 5:49 pm
cyassopoulos
SubscriberProblem Statement
Description of Physical System
For the physical system, a pump will be used to send a fluid at a defined inlet temperature and flow rate into a loop. After a predetermined volume of fluid is pumped into the loop, a valve will close so that only a fixed volume of the liquid is flowing within the loop. Also, within this loop, another pump will continuously pump the fluid at the same inlet flow rate. I hope this description is clear.Â
CFD Requirements
The team would like to use Fluent within ANSYS to simulate and analyze this system. Ideally, we would like to do a transient study, but if this is overly complicated, a steady-state analysis of the flow in the closed-loop is also acceptable. We are having trouble with two key areas of the simulations:
1.    For the steady-state analysis – imposing boundary conditions that model closed-loop flow
2.    For the transient analysis – imposing boundary conditions that model a valve opening and closing
For the closed-loop flow, we originally made a small cut in the loop to create two surfaces. We defined one surface as the inlet with a defined fluid velocity. We then defined the other surface as an outflow boundary condition. However, this led to a massive drop in pressure across the loop that seems unrealistic for closed-loop flow. I think the error may be that Fluent is assuming the outflow is open to atmospheric pressure when in reality the outlet would be flowing into a pump to go through the loop again.
Similarly, for the transient analysis, we are not sure how to define time-dependent boundary conditions. Or how to define a boundary condition that simulates a valve turning off to stop the flow into the loop.
Any insight on how to solve these problems would be greatly appreciated. Thanks.
September 6, 2023 at 10:46 am
Max Hossinger
SubscriberHello,
I've got a very simular problem.
I want to model and simulate a fluid flow in a closed loop / circle.
My problem is, that I don't really know, how to apply an "input" and an "outlet" in a closed loop. Basically there is a pump / vent, which creates a circular fluid flow in the loop. It would definitely help me a lot if someone would have an idea how to model such kind of system, how to apply Inlet and / or Outlet, respectively set the right boundary conditions to make the simulation work.
Thank you!
- The topic ‘Closed Loop Fluid Flow’ is closed to new replies.
3767
1333
1168
1090
1014
