Ansys Products
Ansys Products
Client-side license access for LS-DYNA
    • crd73
      Hi all, thanks in advance for any help.
      I have ( I think ) successfully set up the LS-DYNA license manager on my server machine - the license manager app is running, and my server machine can access the license perfectly.
      I am now trying to set up a client machine which is in-network by means of a Cisco VPN connection. I installed the same version of LS-DYNA on the client machine and set the environment variables for using a network license and pointing to the network name of the server. I also had the IP of the client machine (the non-VPN ethernet IP, not the VPN IP) added to the ALLOW RANGE field of the license.
      Still, when I try to run a simulation on the client machine I get this error:
    • crd73
  • The topic ‘Client-side license access for LS-DYNA’ is closed to new replies.
