June 2, 2021 at 5:27 am
OnurOnder
SubscriberI'm writing a code on ansys apdl commands. But I need to do Solution>Clear genrated data before running the code again. Otherwise it warns and does not give correct results. But if I do clear generated data the results are correct. But I don't want to do this manually all the time. How can I solve this with code?
June 2, 2021 at 1:08 pmAshish Khemka
You can include a /CLEAR command in your script.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v211/en/ans_cmd/Hlp_C_CLEAR.html
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘Clear Generated Data’ is closed to new replies.
Innovation SpaceTrending discussions- The legend values are not changing.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
4162
1487
1318
1170
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
