July 12, 2020 at 5:31 pm
lyip6
SubscriberHello,
I installed Ansys 2020.1. i'm getting an error message when I start ChemKin. Error message says can not find ckjni.dll on the computer.
I verified that the file is there. I even reinstalled Ansys.
Please help.Â
Thank you
July 13, 2020 at 7:04 pm
Karthik Remella
AdministratorCould you please share the screenshot using the 'Insert Image' option? Ansys employees cannot download attachments on this website.
Thanks.
Karthik
July 13, 2020 at 8:48 pm
July 14, 2020 at 3:56 pm
tsiriaks
Ansys EmployeeOpen CMD Prompt and enter the following commands
set PATH=C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem
"C:Program FilesANSYS Incv201reactionchemkinpro.win64binrun_Chemkin.bat" Pro
does this work ?
If not, enter the command
set
and post the output of it here.
Also, do you have an install.err file under C:Program FilesANSYS Inc  ?
Thanks,
Win
July 14, 2020 at 8:08 pm
lyip6
Subscribertsiriaks,
Thank you for your response. Unfortunately, that did not work. Here are the files
July 14, 2020 at 9:28 pm
tsiriaks
Ansys EmployeeCould you post the file content inline ? ANSYS employees are not allowed to download attachment
Thank you.
July 14, 2020 at 9:53 pm
July 14, 2020 at 10:45 pm
tsiriaks
Ansys EmployeeI've never seen most of these Chemkin/Reaction related environment variables. Did you or your IT manually create them ?
I think we should try to remove them but you may want to back it up first.
Please also post the content of your install.err file
July 14, 2020 at 10:52 pm
lyip6
Subscribertsiriaks,
Here is the content of install.err
ANSYS installation: Wed Jul 8 03:03:25 2020
Revision: 2020 R1
  ###### Error #######
  Switch Unknown: Ignoring switch "-disablerss"
We didn't add those environment variables for Chemkin/Reaction.
I'll try to remove them.
July 14, 2020 at 10:53 pm
lyip6
SubscriberWhich variable do you want me to delete?
July 14, 2020 at 11:00 pm
tsiriaks
Ansys EmployeeBasically everything that has the term 'chemkin' or 'reaction' whether in the name or value, just remove them.
What was the installation package name that you used to install Chemkin ? My machine doesn't have any of these set and it can be launched fine.
July 14, 2020 at 11:02 pm
lyip6
SubscriberI used the Ansys 2021 R1 installation media to install this.
July 14, 2020 at 11:05 pm
tsiriaks
Ansys EmployeeThe ISO images ? what's the exact file name ?
July 14, 2020 at 11:12 pm
lyip6
Subscriberit is setup.exe
July 14, 2020 at 11:14 pm
lyip6
Subscribertsiriaks,
I installed the Ansys suite and a clean computer. It is working. However, on this particular computer it is not working. I even tried to reinstall Ansys 2020 R1 Suite.
Thank you for your help
July 14, 2020 at 11:32 pm
tsiriaks
Ansys EmployeeCan you check/post the environment variables of another machine that's working ?
July 15, 2020 at 5:00 pm
July 15, 2020 at 7:50 pm
tsiriaks
Ansys Employeeok, as you see here, there is no environment variables for Chemkin or Reaction set. There might be something wrong during the installation on that machine and somehow the environment variables that were set only in the install wrapper were passed to be permanently set on the machine. Maybe, it's best you uninstall (using the uninstall.exe with 'run as admin') , check if there is any remaining environment variables and delete them. Then, reinstall again with 'run as admin'
July 16, 2020 at 4:14 pm
lyip6
Subscribertsiriaks,
I reinstalled Ansys but it is still not working. The environment variables is clean now.
July 17, 2020 at 12:02 am
tsiriaks
Ansys EmployeeHmm, Can you post the current environment variables on this machine ?
Is there anything new in the install.err file ?
July 17, 2020 at 1:08 am
July 17, 2020 at 4:01 pm
tsiriaks
Ansys EmployeeDoes it still show the same error message ? If so, what is the output of the following command
dir /s "C:*ckjni.dll*"
July 21, 2020 at 4:46 pm
July 21, 2020 at 6:58 pm
tsiriaks
Ansys EmployeeHmm. This is fine.
Can you post the screenshot of the error message again but make sure you expand the window so the entire error message can be seen ? Or if you can copy the text content of the error message and post it here, that would be good too.
July 22, 2020 at 2:37 pm
lyip6
SubscriberPROGRAM ERROR:Â Â
System Message:
C:Program FilesANSYS Incv201reactionchemkinpro.win64binckjni.dll: The specified procedure could not be found
Cannot find/load required library: ckjni
Looked in C:Program FilesANSYS Incv201tpopenjre11.0.4bin
C:WINDOWSSunJavabin
C:WINDOWSsystem32
C:WINDOWS
C:Program FilesNational InstrumentsSharedOpenVINO
C:Program Files (x86)NVIDIA CorporationPhysXCommon
C:WINDOWSsystem32
C:WINDOWS
C:WINDOWSSystem32WindowsPowerShellv1.0
C:WINDOWSSystem32OpenSSH
C:Program FilesZuluzulu-14bin
C:Program FilesSafeNetAuthenticationSACx64
C:Program FilesSafeNetAuthenticationSACx32
C:Program Files (x86)Wolfram ResearchWolframScript
C:Program FilesMATLABR2020aruntimewin64
C:Program FilesMATLABR2020abin
C:Program FilesMicrosoft SQL ServerClient SDKODBC110ToolsBinn
C:Program Files (x86)Microsoft SQL Server120ToolsBinn
C:Program FilesMicrosoft SQL Server120ToolsBinn
C:Program FilesMicrosoft SQL Server120DTSBinn
C:Program Files (x86)Windows Kits8.1Windows Performance Toolkit
C:Program Files (x86)Common FilesAspenTech Shared
C:Program FilesCommon FilesAspenTech Shared
C:Program Files (x86)IVI FoundationVISAWinNTBin
C:Program FilesIVI FoundationVISAWin64Bin
C:Program Files (x86)National InstrumentsSharedLabVIEW CLI
C:Program FilesPuTTY
C:Program FilesTortoiseSVNbin
C:Program Files (x86)Microsoft SQL Server80ToolsBinn
c:Program Files (x86)Microsoft SQL Server100ToolsBinn
c:Program Files (x86)Microsoft SQL Server100DTSBinn
C:Program Files (x86)IVI FoundationIVIbin
C:Program FilesIVI FoundationIVIbin
C:UsersXXXAppDataLocalMicrosoftWindowsApps
July 22, 2020 at 10:26 pm
tsiriaks
Ansys EmployeeI've asked around about this and there are some thoughts
1. Chemkin is a java app ... Is Java installed on the computer and in the user's path? You can use the following commandÂ
set | findstr -i java
2. Chemkin may be having trouble creating its environment, which could result in .dlls not being located. Please use the following command
"C:Program FilesANSYS Incv201reactionchemkinpro.win64binrun_chemkinpro_env_setup.bat" > C:Tempchemkin_env.txt
and post the content of C:Tempchemkin_env.txtÂ
July 23, 2020 at 3:13 pm
lyip6
Subscriber1) The Set | findstr -i java command doesn't return anything.
2) here is the results from run_chemkinpro_env_setup.bat
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set REACTION_DIR=C:Program FilesANSYS Incv201reactionÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_BIN=C:Program FilesANSYS Incv201reactionchemkinpro.win64binÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_VERS=20.1Â
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>call "C:Program FilesANSYS Incv201reactionchemkinpro.win64binrun_chemkinpro_env_setup_part2.bat"Â
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set RD_JRE_BIN=C:Program FilesANSYS Incv201reaction..tpopenjre11.0.4binÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set relinfo_file=C:Program FilesANSYS Incv201reaction..commonfilesglobalsettingsrelinfo.xmlÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>PUSHD C:Program FilesANSYS Incv201reactionchemkinpro.win64binÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>FOR /F "tokens=*" %a in ('ReadRelinfoExt.BAT') do set extvers_file=%aÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set extvers_file=C:UsersJOHNUSERAppDataLocalTemprd_89973240_ext.tmpÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>FOR /F "tokens=*" %a in ('ReadRelinfoInt.BAT') do set intvers_file=%aÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set intvers_file=C:UsersJOHNUSERAppDataLocalTemprd_61847882_int.tmpÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>FOR /F "usebackq delims==" %g IN (`type "C:UsersJOHNUSERAppDataLocalTemprd_61847882_int.tmp"`) DO set CHEMKIN_INT_VERS=%gÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_INT_VERS=201Â
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>FOR /F "usebackq delims==" %g IN (`type "C:UsersJOHNUSERAppDataLocalTemprd_89973240_ext.tmp"`) DO set CHEMKIN_VERS=%gÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_VERS=2020 R1Â
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>DEL /Q C:UsersJOHNUSERAppDataLocalTemprd_61847882_int.tmp C:UsersJOHNUSERAppDataLocalTemprd_89973240_ext.tmpÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>POPD
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set BUILD_DATE_FILE=C:Program FilesANSYS Incv201reactionchemkinpro.win64build_date.txtÂ
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_TITLE=ANSYS Chemkin-ProÂ
July 23, 2020 at 3:15 pm
July 23, 2020 at 7:35 pm
tsiriaks
Ansys EmployeeThe machine doesn't have Java installed.Â
Can you install Oracle Java and make sure your Path environment variable has this in there
C:ProgramDataOracleJavajavapath
Does this make a difference ?
July 24, 2020 at 12:30 am
lyip6
SubscriberI installed oracle java it is still not working. I see C:Programdataoraclejavajavapath in %Path% now, but it is still not working.
July 24, 2020 at 12:54 am
tsiriaks
Ansys EmployeeCan you try moving this entryÂ
to be the first value of Path environment variable ?
July 24, 2020 at 2:42 am
August 4, 2020 at 6:56 pm
tsiriaks
Ansys EmployeeI've consulted with developers. nHere are their comments and questionsnnThere can be incompatibility between some system dll on the machine and jni.dll in our install. nSome questions to ask the user are:n1) does the user have correct permissions to read/execute ckjni.dlln2) Is there a virus or malware software blocking execution?nnLet us know.n -
August 17, 2020 at 6:17 am
lyip6
SubscriberHello tsiriaks,nIt has been awhile since I provided an update. I was trying to update this thread but your site was under maintenance so I couldn't update it. So I found out that this started after I installed Aspen 11. Then I reinstalled everything from scratch with Ansys 2019 R1 and Aspen 11. I didn't get the problem with Chemkin. At this point, we decided to keep using Ansys 2019 R1. nThank youn -
August 18, 2020 at 9:56 pm
tsiriaks
Ansys EmployeeHi lyip6,nThank you very much for the update. That's great find !nAspen 11 might have put some DLL's or files under Windows systems files directory, which inadvertently makes Chemkin use that same file and result in issue because it's not compatible.nIn any case, I'm glad it's working with 2019 R1. I will report back to developers in case they can check Aspen to see what causes the issue.nThank you.n -
February 8, 2021 at 10:45 pm
braddonegan
SubscriberHi Array ,nThank you for this post as it helped us troubleshoot this issue. We have a setup which requires both ANSYS 2020 R1 and Aspen Plus 11 to be installed.nRemoving or renaming the specific DLL, C:\Windows\System32\svml_dispmd.dll, fixed this problem for us. This DLL is not needed in how we use Aspen Plus.nWe had a similar problem with Fluent several months ago and had to use a similar fix but with a different DLL.nProbably not possible, but it would be great to have an option that tells the ANSYS apps to ignore external libraries.nThanks!n
- The topic ‘Chemkin start error unable to find ckjni.dll’ is closed to new replies.
5824
