September 26, 2024 at 4:25 pmphilSubscriber
My students have been using Chemkin for a few years but our University license is no longer good enough because Chemkin wants to call HPC resources which aren't part of the University license. When using V232 everything works on our Linux and Windows PCs. This problem started when we switched to V242
Logfile:
11:44:33 (ansyslmd) UNSUPPORTED: "anshpc" (PORT_AT_HOST_PLUS  ) user@machine [1699077] (No such feature exists. (-5,346:104 "Connection reset by peer"))
11:44:34 (ansyslmd) UNSUPPORTED: "anshpc_pack" (PORT_AT_HOST_PLUS  ) user@machine [1699077] (No such feature exists. (-5,346:10 "Connection reset by peer")) -
September 30, 2024 at 10:34 amRajeshwari JadhavAnsys Employee
Hi Phil,
It says unsupported, so can you check expiration date of licenses? also the license manager should be of v232 or higher to use v24x application on client end.
-5 error means you don't have license.
October 1, 2024 at 8:18 pmphilSubscriber
There is no HPC license with the UNIVERSITY package. Our licenses are fine. If I run V232 CHEMKIN works fine.
V242 doesn't work because CHEMKIN make calls to HPC. I need the University license to include HPC licenses or be able to turn HPC off for CHEMKIN
ANSYS created this problem by getting CHEMKIN to make calls to HPC...which we don't need.
Give us some HPC licenses to fix the problem you created or tell us how to turn off the calls to HPC.
October 3, 2024 at 4:38 pm
October 4, 2024 at 9:37 pmphilSubscriber
We tried your suggestion...HPC licenses were still checked out. Did you want me to try it without the HPC licenses in the license file?
October 7, 2024 at 8:27 pmRajeshwari JadhavAnsys Employee
Hi Phil,
It seems like there is some issue with chemkin, developers are checking into it. Will let you know if there are any updates.
October 14, 2024 at 9:26 amLeeSubscriber
We seem to be having the same issues as mentioned by the OP within our university setup, I was wondering if there is an update or solution to this please? Again, we did not have this issue to the previous years version and has only become apparent now that students are trying to use Chemkin.Â
Thanks
October 14, 2024 at 1:33 pmRajeshwari JadhavAnsys Employee
Hi Lee,
The development is working on this, if you already have a license please contact your AM for HPC licenses.
October 14, 2024 at 1:31 pmphilSubscriber
We've been given a temp HPC license to carry us through the term...hopefully the problem will be fixed sooner than that.
- Chemkin requires HPC
- Battery Simulation – Cannot access User-defined scalar (UDS) diffusivity
- Calculate heating of an assembly for a given ambient temperature?
- Doubt clarification on seed generation using ANSYS ADPL
- S-N (Wohler Graph) for steel X153CrMoV12 / D2 / NC11LV / K110 or similar
- Material Designer: Meshing difficulties
- Analysis of Shape memory alloys
- chemkin
1081
447
395
225
201
