TAGGED: ansys-chemkin, chemical-reactor, chemistry, nox-emissions, reactions
December 9, 2024 at 6:03 pm
magdalena.krainz
SubscriberHello,
I am wondering, if it is possible to define a reactor network in Chemkin using an input file. For example I would like to create a reactor network with 20Â reactors and many connections between them . If I would do it by hand it would take ages and there would be errors for sure. Is there a possibility to define the whole network using files which define the temperatures, volumes, pressures, mass flows, etc.?
December 10, 2024 at 4:10 pm
judy.cooper
Ansys EmployeeHi:
I don't think this is possible, since there is no way to read input files without having a project. Clustering reactors allows you to enter a lot of properties for all reactors in a cluster at once, however. Defining clusters is outlined here in the Chemkin Getting Started Guide:
https://ansyshelp.ansys.com/Views/Secured/corp/v242/en/chemkin_gs/ch02s03.html
