January 16, 2025 at 6:11 am
Masataka Nakamura
Ansys EmployeeAfter onboarding, we provide some check tools to ensure that your environment for Ansys Access is set up correctly.
/ About Check Tools
The following tools are currently available. The tool will be updated from time to time。
o ① A tool to check the connectivity of a VM to an external domain
§ You can use the following scripts to check the connection with the external domain required for the use of Ansys Access.
o For Windows VM: check-domains/check_domains_win.ps1
o For Linux VM: check-domains/check_domains_lin.sh
o ② A tool to check the connection to the license server
§ You can use the following script to verify connectivity to a specified license server from a VM deployed with Ansys Access.
o For Windows VM: check-license/check_license.ps1
o For Linux VM: check-license/check_license.sh
o ③ Tools to check Azure settings
§ You can use the following script to check the Azure settings required to use Ansys Access.
o Service quotas: check-quota/check_quota.ps1
o Enabling Rocky Linux: enable-rocky/enable-rocky.sh
/ How to use
1. Download zip file from GitHub page
a. Access the following GitHub repo
i. https://github.com/masataka1206/aaa-diag-scripts
ii. Download tools as a zip file
2. Extract ZIP file
3. Check README.pdf file and Execute scripts
