September 27, 2017 at 11:19 am
admin
Ansys EmployeeHow can I check the unsteady (transient) sampling times?
October 17, 2017 at 6:41 am
admin
Ansys EmployeeFor transient calculation data, for which a time averaging process was carried out, Fluent samples time from the instant time averaging is turned on and uses it for averaging. if you want to check the sampled time used, enter the following TUI command which returns the time used for time averaging: (rpgetvar 'delta-time-sampled).
- The topic ‘Check the unsteady (transient) sampling times?’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1495
1386
1209
