February 3, 2021 at 10:53 am
Geo573
SubscriberHello, nI am king of new in Fluent. I am currently working on a valve I would like to know, is there a way for fluent to tell ma that the fluid covers the entire of the inside of the valve ? nThank you !n -
February 3, 2021 at 11:29 am
Forum ModeratorThe fluid covers all of the fluid region. Do you mean if a liquid phase fills something up? Have a look at the courses (menu at top of the page) and I think you'll have a better idea of what CFD does. n -
February 3, 2021 at 12:08 pm
Geo573
SubscriberThank you for your answernnWell what I means is that I have conditions for the fluid entering the valve, and I'd like to make sure that the fluids fills up the entire valve before getting out of it.nnIs this possible to check on ? n -
February 3, 2021 at 1:37 pm
Karthik Remella
AdministratorHello,nYes, this is possible in Fluent. Please let us know the exact goal of your simulation (similar to - I'm interested in understanding how long it takes to fill the valve). And we will try to point you to the relevant resources.nKarthikn -
February 3, 2021 at 1:46 pm
Geo573
SubscriberThank you Kremella for your answernHere is what I'm trying to do. I have a valve that is supposed to be cleaned by a fluid. Before realizing in real conditions, I have to check with Fluent if the fluid will well cover the all inside of the valve to clean it.nSo for now I've realized the CAD with design modeler, the mesh with 5 inflation layers with a first aspect ratio of 1.2, and in the setup used a k-eps model with Enhanced Wall treatment, with liquid water, with boundaries Velocity inlet (1.5 m/s, with Intensity & Hydraulic Diameter methode, 5% turbulent intensity and 0.05 m as Hydraulic Diamter (the valve is DN50)), Wall and Pressure Outlet. I use second order upwind solution methods and Standard Initialization, with Absolute Reference Frame computed from Velocity Inlet. Correct me if this is wrong.nNow I can check several results but can't seem to find anything about if the fluid covers the entire valve.n -
February 3, 2021 at 2:00 pm
Forum ModeratorFluid means any gas or liquid (and to complicate things granular solids). So in your model the fluid has to cover all surfaces. I think you need to look at the VOF model if you're looking to see if a liquid fills something normally full of gas. n -
February 3, 2021 at 2:13 pm
Geo573
SubscriberThank you could you detail what you mean by VOF model please ? n -
February 3, 2021 at 2:34 pm
Forum ModeratorVolume of Fluid, it's a multiphase model for free surface tracking (ie water and air with with a continuous surface between the two). n
Viewing 7 reply threads
- The topic ‘Check the path of the fluid’ is closed to new replies.
1681
1387
1248
