Preprocessing
Preprocessing
Check the mesh skewness in Fluent 19.3
    • Ramy
      Hi all,
      I created my 2D mesh (fluent workbench) and imported it to the solver (fluent). I did some improvements in the mesh in the solver by using TUI commands and Now, I want to check the mesh skewness through "check mesh quality" but only the orthogonality and aspect ratio appear not the skewness. In older versions the skewness quality values used to appear as well but in the verison I am using now (19 R3) it does not. How can I check the skewness values?
      Thank you.
      I think you can change the quality metric, if not initialise the solution and use the contours of Mesh -> Skew to check the results. There should be a TUI report of the quality during the smoothing process, check it's not in there too.  Note, I'd always fix the mesh in the meshing tool as you have more control over the results.
  • The topic ‘Check the mesh skewness in Fluent 19.3’ is closed to new replies.
