3D Design
3D Design
Check Geometry In spaceclaim
    • Agung Limowa
      Hi, i have geometry exported from CAD to Design Modeler as slice material (The case is about duct inside a tunnel), there is some error in geometry which makes me have to check geometry in spaceclaim. does my "slice material" setting changed? if so, anyone can help me set it again ?
    • Aniket Chavan
      Can you provide some more details about error and your workflow? Are you using SpaceClaim or DesignModeler? Do you mean to use "add frozen" option in DesignModeler instead of slice?
      -Aniket
    • Agung Limowa
      Hi thankyou for the question i've solve this problem
  • The topic ‘Check Geometry In spaceclaim’ is closed to new replies.
