Photonics
Photonics
Charge simulation with single photon
    • sagar
      I want to do a charge simulation with a single photon for my device, which creates a single electron-hole pair inside the material. I want to do a transient current simulation I vs t. What should I use as a generation source? Shall I use delta (point source), and what should the global source shutter parameters be? Could you give some suggestions?
    • kghaffari
      Good question. I think delta source would be ideal because you can easily specify the number of electron hole pairs (ehp) to be injected in the simulation. With only one ehp simulated I expect the current to be very low. The delta source works with transient simulation so you should be able to obtain I-t.
      You can also obtain the collection probability of the ehp vs it's location; this can be done by enabling the "map current collection probability" option in the contacts. This approach is used in our example here (please refer to step 4): https://optics.ansys.com/hc/en-us/articles/360042358574-CMOS-image-sensor-Angular-response-3D
      Let us know if you have further questions.
  • The topic ‘Charge simulation with single photon’ is closed to new replies.
