August 8, 2024 at 1:57 pm
ph23resch01002
SubscriberDear Sir/Madam,
I am currently using Lumerical Charge to simulate an active metasurface unit cell. I have attached a picture of the unit cell for your reference. I will briefly describe the unit cell structure:
The unit cell consists of a SiO2 substrate on which a Si slab is placed. On top of the Si slab, there is a GaAs layer, followed by an Al2O3 layer, and finally Si resonators. The voltage is applied between the Si resonator and the GaAs layer using the electrical connection boundary condition.
I attempt to sweep the voltage from 0 V to 12 V to observe the charge distributions. The simulations run smoothly up to 8.5 V; however, beyond this point, the simulation halts and displays the attached error.
I have also checked the online references for troubleshooting this issue and made the following adjustments in the Charge Solver advanced settings:
- Solver type: Kept as Gummel.
- Global iteration limit: Increased from 40 to 50.
- Gradient mixing: Changed from Disabled to Conservative.
- Update limiting values: Decreased.
Despite these changes, the problem persists. Could you please assist in resolving this issue?
Thank you for your support.
August 12, 2024 at 8:51 am
Niki Papachristou
Ansys EmployeeHi Bharathy,
Thank you for reaching out to us. For you case may I ask you whether you have checket your CHARGE simulation using the Partitioned volumes in finite element solvers - Simulation object?
After partitioning the sumulation if you have a none in one of your domains means that you dont have a material there and the simulation might be stoping for that.
Let me know if that's the case.
Kind Regards,
Niki
3139
1007
918
858
792
