January 1, 2024 at 7:02 pm
fparveen
SubscriberHello,
I am doing 'characteristic mode' (solution type) analysis of a vivaldi antenna.Â
Is there any way to plot the antenna surface current (Jsurf) for each mode?Â
ThanksÂ
January 5, 2024 at 12:30 pm
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum.
It is possible to plot the fields for all the analyzed modes using the Characteristic mode solution type.
Please modify the magnitude of the modes available under Excitations>Edit Source to excite the specific mode for viewing the fields.
Best regards,
Praneeth.-
January 5, 2024 at 7:30 pm
fparveen
SubscriberThanks. But I used no excitation source for characteristic mode solution type.
January 25, 2024 at 4:53 am
Praneeth
Ansys EmployeeHi,
It is not required to define the excitations for characteristic mode analysis solution type. The post-processing of the modes analyzed by the tool is available through this edit sources option.
Best regards,
Praneeth.
- The topic ‘Characteristic mode analysis: how to plot antenna surface current for each mode?’ is closed to new replies.
