TAGGED: antenna, antenna-design, antenna-efficiency, antenna-parameters, antennas, hfss, hfss-15, HFSS-Ferrite
October 13, 2023 at 4:43 pm
October 17, 2023 at 3:04 pm
Praneeth
Forum ModeratorHi Imtiaz,
Thank you for reaching out to the Ansys learning forum.Â
It is possible to edit the trace name. Please select the trace in the Project Manager window > in the properties window check Specify Name > enter the desired name.
For more information on creating and modifying reports, please go through the "Post Processing and Generating Reports" chapter in the HFSS help pdf document.
Best regards,
Praneeth.
- The topic ‘Changing trace name in HFSS?’ is closed to new replies.
Ansys Innovation Space
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Ansys-MATLAB Co-Simulation
- Compute near field simulation with current
- Ansys Resonance simulatioin error
- Double-sided LIM external circuit error
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
965
841
599
591
