October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeHow can you change the tolerance for boolean operations?
October 18, 2017 at 5:12 am
Arun Kumar
Ansys EmployeeCheck the default value of tolerance for boolean operations through BTOL, STAT command. Provide a tolerance value about 1/20th to 1/10th of the minimum KPT distance using the BTOL, tolerance value
- The topic ‘Changing tolerance for Boolean operations?’ is closed to new replies.
